Styles Ryzer Pro 2.2.12
Ryzer Pro
It has exciting features and excellent code quality.It has been designed and developed after thorough research to cater the requirements of people who interested in building user based directories. The design is contemporary but at the same time it focuses on the usability, visual hierarchy and aesthetics to ensure easy navigation for the end users.
37.50 $
65.00 $
48.75 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi System Requirements Sürümler (23) İncelemeler (1)
A new update is available for Ryzer Pro by XenTR.
Ryzer Pro 2.2.12
This update fixes a few minor bugs, also addresses the outdated template that is appearing on the latest version of XenForo v2.2.12
Before Upgrading:
  • XenForo 2.2.12 compatibility
Why your footer copyright shows on every theme (default theme and other)? It's weird.
Which answer button are you talking about?
An arrangement will be made regarding this.
Copyright information is not included in the themes own templates. In the master structure, copyright information is included in the add-on.
For example, you buy a plugin and the copyright information of this plugin is visible in all themes. For this, it is necessary to buy with copyright at the time of purchase.
I didn't disable the default theme. All members can choose that theme. So why should your copyrght footer appear there?
I just realized this.
Okay i got it.
Sub-forum not displayed on mobile. Is there a way to display it?
Please help.
For no.1, I want my members to go straight to the question type threadinstead of discussion thread. I mean, they landing on the question tab.
For no. 2, I want visitors to see all of the question-specific lists.
It happened again sir, it seems that automatic adsense is not suitable for Ryzer Po themes.
Indeed, the appearance can return to normal after the page is refreshed several times. But it does come back sometimes.
Not recommended if you are using an older version other than XenForo 2.2.12. We recommend using the current XF version.
  1. ryzer pro
XenForo 2.1.x + XenForo 2.2.x XenForo 2.3.x
37.50 $
65.00 $
48.75 $
